Off Paco Goes...
pacodiablo
This Sunday I will head down to AL for a couple of weeks. This means a temporary change of rides. I can't take the Ranger, the parents need it here, so I will be driving a beat up '98 Blazer 2-door belonging to my cousin for use in his business. Should be interesting. The Blazer has a history of electrical gremlins, so hopefully it will be working.
Have a safe trip.
Does this mean the lawn mower work goes on hold for a while? No more update posts???? :D
By the way did you ever get to Hoods for those carb parts?
Have a safe trip.
Yeah, the MTD will be under a tarp for the next 2 weeks...I am hoping the parents don't junk it while I'm gone! :mad:
I did not get a chance to go to Hoods yet, I may when I get back.
I had a rider project once. Came home one day and it was in a bunch of pieces. Half in the trash and half in my uncles truck going to fix up his old rider. :D
Thats cool, have fun. :D
I'm on vacation right now my self. I also set a new personal record for the drive. 340 miles in a little less that 4 hours and 30 min. Thats an average of 79 mph, man I hual ass.
