Dash light help
ok everyone im new here and I need your help.
I have a 2006 chevy 2500hd and im at a loss to what to look at next. all the lights on my dash and insturment cluster work exept the back lights for the gauges. I have tested ALL the fuses and there good. I replaced the headlight switch and fog light switch and even replaced the insturment cluster still nothing. please help.
If you've replaced the instrument panel itself and the gauge lights still don't work, and all the other lights on the dash respond to the brightness dial, then it's likely a wiring and/or connector issue for the I.P.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,071 Guests (See full list)
