2002 Sierra bumper
Will a 2002 GMC Sierra front bumper fit on a 03 Sierra?
Sent from my N9519 using Tapatalk
Not thinking so. The front end changed on the Chevy's and gmcs in 03. Google those years and you'll see the difference.
Sent from my E6810 using Tapatalk
No. Different frame horns and brackets. I had to change those to go to the Denali front end which uses the 99-02 ones
So what would I have to buy to change the brackets in order to make it fit?
Frame section to weld on the frame horns, brackets, supports, chrome bumper, lower plastic bumper, a ton of plastic rivets, and 2003 grille.
I got this at a wrecking yard off a Tahoe for $65. SUVs used the 99-02 setup all the way through. You need a non Denali 03-06 1500 truck setup
Cut and welded here
He wants to put an 02 bumper on to an 03...so wont he need a 99-02 set up?
I was thinking the other way. So the 99-02 truck or 02-06 SUV frame section, bumper brackets, and 02 grille. Same list of parts but for the 99-02 truck or the SUV from 02-06
OK thanks for all the info! Seems like a little bit too much work for me I was just hoping it would Bolt right on lol
If you have a friend who can weld, that is the hardest part. Then you have to just collect the parts.
I know how to weld, just don't have a welder... And I don't really know anybody with one
Get a cheap one from tractor supply or harbor freight
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,208 Guests (See full list)
