Diablo intune
I'm selling my Diablo Intune I-1000 it's unmarried from my vehicle. I had it on a 2015 Chevy Silverado 1500. But will work with other vehicles also. I have the original box along with obd2 port cord and USB cord to do updates if available. I'm asking $200 shipped OBO.
I believe that the I1000 can only be used on one vehicle at a time but you i2030 you can use the same programmer on multiple vehicles, but u have to buy a new license each time.
