Brakes and 35's. Lets Talk
Hey guys. Was searching around a bit but didnt find too many hits on this.
I have 35" tires and currently, the stock brakes. They are making a brake grinding sound if you will, even when off the brake pedal. (driver side front brakes) Around 25-30mph is when you can really hear the repeating grind/scraping. I put it in 4h and the noise was increased even more so. The sound pretty much stops when the brake pedal is pressed oddly enough
The rotors and pads need to be replaced soon im about 99% sure of this.
my question is, when dealing with 35" MT tires, what are you guys recommending/running on your own trucks? A buddy of mine has recommended a more heavy duty towing type of pad/rotor combo.
thanks
Different trucks, I know but I have an 01 z71 that's on 37s and I run those green pads. Seem to do the job nice enough that I don't have to worry about it
Ive been wanting to upgrade my brakes since i run 35s, might go with wilwood or baer, havent decided yet
