DL3 Mirrors
Goody15o
I have a 2016 Silverado Z71 LT that came with DL8 mirrors. I purchased some DL3 mirrors (glass only) in hopes of upgrading. I took off the door frames and stock glass and realized I was missing the wires to the turn signals on the DL3 mirrors. Do you know where I can get the wire I need or do I need to buy the whole housing DL3 mirrors? Thanks!
I suppose you could add the wire needed into your mirror harness.
There is someone selling a set of DL3's on the board for $250 and taking offers so he may take less....that's a phenomenal price.
They usually go for a bit over $300 / set.
That would give you power fold / puddle / signal and auto-dim..if you put the harnesses in for it.
Might want to read through this a bit as well.
I believe the connector p/n's will be mentioned in there that you will need to add.
http://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-mirrors-explained/
and also
http://www.gm-trucks.com/forums/topic/178860-how-to-install-dl3-mirrors-in-2014-lighting-only/
Note that Phil is the most comprehensive on this subject. Might want to PM him with your questions.
Search these forums or send a PM to "pgamboa". He is the mirror guru and has figured out all the pins. He even makes custom harnesses that will make the mirrors plug-and-play.
EDIT:
Sorry - I just read Vicarod's post above. Phil is the pgamboa I was talking about.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
