Heater stopped blowing in my 99 Silverado
Mamaliz82
So one minute my heat was blowing fine. The next time I tried to use it, no air would blow. Now there's still heat coming from the vents, but all settings are like I put it on 1. I checked both fuses that go to climate control. They are intact. I need some ideas, before I rip my truck apart, trying to fix the issue. I really don't want to bother my mechanic with something so trivial. I do have a repair manual. However, it didn't have an answer to my problem. Help!
Blower motor resistor [emoji1417] under the dash right side. Make sure connector isn't burnt up when you disconnect it
Also check the connectors where they plug into the blower motor,they can come off.Mine did.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
