First Error Code at 45K
Guess I have been lucky, just got my first check engine light yesterday after work. Trucks is at 45K.
Checked last night when I got home, P0451, evap pressure sensor error.
I just cleared the code and seeing if it comes back.
Anyone else gotten this code?
Yes, more than likely the fuel tank pressure sensor is causing this. This code is checked when the engine is off, there's a small vacuum test that's done when the P0442 test is done. If the ECM is unable to see a zero pressure during the engine off test it'll set this code. Most of the time when the sensor is skewed, it'll read around 0.27-0.54 inHg on the scan tool. Most the time you can just unplug the sensor and watch the data again and you'll see it'll go to 0.00 inHg. Then you know it's the sensor. It's above the fuel tank mounted on the fuel pump module.
I had the same code pop up in December, I unhooked my battery and it hasn't come back since. I think you have to drop the tank to change the sensor so I was trying to avoid that if possible.
So far the code has not come back on, and hopefully will not. I would rather not drop the tank to change the sensor.
  • 3 months later...
Same issue occurred on my Silverado around 40k. It was so bad I could not fill up using automatic shut off pumps. Had dealership fix the issue because you do need to drop the tank and did not have time to mess with it. Wish I had still been under warranty, expensive fix, over $500.
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 834 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
