Leveling Kit with 18's
Navo
I have a 2016 Chevy 2500 with the 18 inch Steelies. I think their +44 offset. What's the biggest tire size I can run with he Rough County 2.5 inch leveling kit installed. I have removed the front air dam plastic piece so any rubbing won't be a problem with that.
I looked the fourms over but can only find good amount of info on the 20 inch rims.
Thanks in advance for your help!
295/70/18 should work. Probably going with a 295/65/18 duratrac on mine:)
So a 305/70/18 won't fit? It's .4 inches wider and .5 inches taller.
Then I saw where people are running 35's on 20 inch rims? I can't run 35x12.5 or 35x11.5 on the stock 18's?
A 305/70/18 will be close, depending on the exact brand and tread you choose. There's a member running 35x12.50x18's with a level and stock 18" rims. However, he's running BFG's, which tend to run a bit smaller than other brands. You may need to trim a little to clear a true 35x12.50.
What would have to be trimmed? the rear part of the inner fender well?
I was thinking either Toyo MT, NITTO MT, or the Cooper STT PRO's
Either the front section of the fender liner (or pull it back with zip ties), or the mud flaps (if you're running them).
    Whit.the.COB
    Whit.the.COB
  • Who's Online   3 Members, 0 Anonymous, 1,251 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
