Brembo brakes
I've been wondering the same thing with no response. I think $2k for big brakes is pretty steep for most and if there's $2k to burn for mods, they're doing something else with the cash.
I have the Wilwood 14.25" front kit. I believe it's comparable to the Brembo factory kit. I got this kit before the Brembo factory kit came out. I'm very satisfied. When I put 33 x 12.50 tires on it, the factory brakes just weren't comforting. These brakes really made a difference. If you run 20" wheels, you can use their 16" kit, which should make even more braking power.
Where you'll notice it is in the pedal force and resistance to fade during freeway speed stops, on downhill stops, and stopping when heavily loaded.
I use my truck for hunting, commuting in the burbs of L.A., and vacations. When in the traffic on freeways in L.A., there are many times heavy braking is needed. With the big tires, topper, and bed vault drawers, it needs more braking power than the stock brakes offer. Also, when I load up for a trip, there is a lot of weight added on top of that.
Most people will spend their money making their trucks faster rather than making them slow down better. I have a car that gives me "fast" (SS Camaro with Brembos). Either the Brembo or Wilwood brakes will give you more safety margin in your brakes.
When you put large diameter tires on a vehicle, it provides a longer moment arm (longer lever) which makes more force on the brakes, equating to a loss of braking ability. These large brake kits get back the loss of braking from larger diameter tires.
Yeah, $2k is a lot of money. But so is banging up your truck because you didn't stop in time. I recommend them if you can afford it. If you want to save a few bucks, compare the Wilwoods to the Brembos. There might be some difference.
For guys running 18" wheels, Wilwood offers the 14.25" 6 piston front kit. They also offer a 16" front kit that is similar to the OEM Brembo size.
If you're running 20" wheels, go for the 16" brakes. Bigger is better when it comes to brakes. For 18" wheels, you're choice is limited to the 14.25" diameter. Wilwood also offers a 14.25" 4 piston rear kit.
http://wilwood.com/BrakeKits/BrakeKitSearch.aspx?year=2014&make=Chevrolet&model=Silverado+1500+Pickup&option=6+Lug+-+All
Thanks Spurshot. That gives me something to think about. I was really dissatisfied with the brakes when I first purchased the truck and continue to be. What really scared me was towing a 6-7000lb mini excavator and trailer. I don't do that a lot, but I'd sure like to feel more comfortable in those situations and during regular driving.
THanks spurshot. Happen to know if the brembo factory kit comes with real discs or drums? If discs, it would be nice if they painted the rear calipers red to match the front.
My buddy works at Chevy and he said if you use the wilwood or baer brakes you have to get the computer flashed so your and works. Is this true ?
No computer flash is required. The OEM anti skid sensors are retained with the Wilwood brakes.
If you want to know more about Wilwood brakes, Blackbear is a dealer. Jenna has them on her truck.
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
