Exhaust chirp
I have a 2000 gmc sierra 1500 5.3 with true duals no cats I recently put full soze glass packs on it then I started it this morning and there is a chirp coming from the driverside pipe. I check for leaks couldn't really find anything then i was wondering if a valve or something is bad so i put a piece of paper over the exhaust and there is a flutter out of both pipes so i got scared thinking a valve is burnt or stuck but i am not down on power it starts right up and fuel millage is normal so i dont know if i just got a bad glasspack and its chirping through something but any help is appreciated thanks.
I would visit an exhaust repair shop. Don't pay anything, this should all be free. Ask them to listen to it (Or a recording of it). They will put it up on the rack, and check all the normal culprits. If they can find a problem, ask them for a free estimate on repairs. Take the vehicle to another shop, and ask them if the repair estimate you were given is correctly diagnosing the problem, and what they would charge to fix the same problem. If you pay for an exhaust repair to fix the problem, don't do it unless they guarantee it will solve the problem or refund your money. Any shop that is doing things properly, will agree to these terms. They won't waste your money that way.
It could be unburnt fuel entering the exhaust, due to the cold start engine management adjustments (richer fuel trim) Normally a stock exhaust system would hide these sounds. If you went to strait headers, I bet you would hear some more engine noises that you are not accustomed to as well. Modifying the exhaust can effect engine performance, noise, fuel economy, power output, etc.
The stock setup is the best all around exhaust system for general use. Its also good, because the first set is free (already on the vehicle). Racing demands better flowing exhaust, either by increased pipe size, or removal of restrictive components. Most people buy exhaust for a "better" or "louder" exhaust sound.
If you have a burnt or stuck valve. Symptoms would be:
Low or No compression in a particular cylinder
Compression does not increase after oil is added to combustion chamber
Engine shaking more than normal.
Check engine light on,
OBD2 code referring to: cylinder misfire, especially a particular cylinder
OBD2 O2 sensor codes
Decreased fuel economy
Smell of fuel in the exhaust
Backfiring
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
    • Great video. I almost want to reserve one now.
    • I traced the atf cooling system in my 1500 and it comes out of the transmission, into the bar/plate liquid/liquid heat exchanger, as stated above.  Then it crosses over to the external thermostat/bypass and then  to the aux cooler in front of the main radiator.  Hence, on this routing, the PPE thermostat bypass eliminator is an $85 piece of bling that does nothing for reducing atf temps on this truck.  I think I'll temporarily clamp a needle nose vise grip on the coolant feed hose to the bar/plate cooler and see how much the atf temp drops.  With the use of ULV trans fluid, I'm not convinced running the trans cooler than OEM spec is going to be detrimental to the life of the transmission.    I found this interesting on the Dana/Long site stating that they make transmission cooling/heating bar plate heat exchangers.  I worked with Dana/Long on a few projects when I was at the gas powered fun factory. https://www.dana.co.jp/downloads/PTG/Long/Dana_TOC_SpecSht.pdf  Bar plate heat exchangers are just a stack of stamped parallel path fluid channels, assembled and vacuum furnace brazed to make the final assembly.  Want more cooling/heating, just stack more plates until you run out of package space.   Anyway, thanks for the info, much appreciated.
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
