First time truck buyer - need help!
Because that's what they really cost
They are the highest volume dealer in the country. They don't give you much for trade-in and they don't negotiate.
Well in reality I don't think any dealer gives much for trade-in, since when they offer you more on the trade-in they are making it up somewhere else, which really isn't offeeing you more to at all.
I love Laura based on reviews, I didn't know they existed when I bought my truck. Sounds like the perfect dealer if you ask me. No negotiating just cheap prices, resolves everything we hate about new vehicle shopping.
Wow that's good to know!!
I dont think the OP wants a floor mounted shift lever, rather 4wd and and the center console storage area normally found on the LTZ, HC and Denali trims. I think if you want a 4wd. Floor mounted shifter you have to go with the WT trim.
Lol..I read it again and I'm sure you're correct. I guess I read into that incorrectly. Thanks
Sent from my E6810 using Tapatalk
20% off msrp minimum this time of year as 18s are weeks away...
Sent from my SM-T350 using Tapatalk
Find your preference in a truck fresh off a 24 month lease and pay cash.
This may seem like a deal vs. MSRP, but no one pays MSRP. Save a couple grand to buy a question mark, no thanks...
Just a question about your preference on a floor mounted 4x4 selector. Is there a advantage nowadays? I'm not one for all the gimiky gadgets we're getting on it vehicles now but I do love the auto feature on the transfer case. Is the lever mounted selector actually a more reliable system? Is there a mechanical connection or is it still just a lever that actuates a electrical switch?
I am going to install a console safe for concealed carry purposes.
If I was trying to buy one new, I'd print out the comparable lauragmc truck to my local dealer and be like, look, gonna cost me about $1k to fly there and drive home. Can you match this plus $1k. I am also Trying to get Insurance for Pick up truck, Have you got?
If that's the extent of your negotiating skills I can imagine the sales manager smiling, shaking your hand and saying "bye, have a safe flight".
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,286 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
