Front grille and color matching swap
I am in the market for a 2017 Silverado 1500. Due to needing the Max Towing Package and 6.2 engine with 8 speed, I can only get the LTZ body style. I don't like all the chrome.
Am I able to change the whole front grille and surrounding chrome with a Z71 color match style? Will it match up and fit.
Yes or No.
Yes or No.
Yes it will all fit. There is a thread on here of two members that swapped. The piece that is on the headlights is taped on like body moulding, so you'll either have to swap lights also or pull that piece off and swap/paint.
http://www.gm-trucks.com/forums/index.php?/topic/202031-Looking-to-swap-bumpers
Can you get max tow on a ltz z71? I didn't think you could.
No...NHT is not available with any Z71
Why not get the z71 ltz? Save yourself time for swapping
He can't, he wants the NHT max-trailering pkg which is not available with Z71.
Get the 2017 GMC All Terrain. All monocolor no chrome anywhere and 6.2 max tow available
The reason I did not buy a Silverado was the chrime trim and wanted the 6.2 max tow
So am I to understand, that if I choose to get the LTZ with the max trailering package I could completely switch the grill and the lights and bumper for a Z71 color matching front end?
Everything would fit to the matching contact or bolt patterns correct?
  • 3 months later...
For my 14 Silverado....I had both my bumpers powder coated $160 for both....my headlight bezels vinyl wrapped $50 for both....and then paid for an OEM grille to color match my truck $300....while selling my stock OEM grille in return $175....
hope that helps!
    DaleB
    DaleB
  • Who's Online   3 Members, 0 Anonymous, 1,109 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
