Garbled Intellilink Radio Screen
Issue Solved.
Hi Everyone,
Has anyone ever seen this happen on their truck?
I'm not a huge fan of the Intellilink system. It reminds me of using computers in 1989: it's frustratingly slow (5-7 secs to change songs when connected to an iPhone), inconsistent performance, the user interface is ugly/dated, and the huge screen really tells me nothing. My 2015 has 43,000 km on it and tonight the radio screen decided to do this. Seems to be the only screen (i.e. other screens/menus not affected). I started the vehicle 3 separate times and it did the same thing each time however on one occasion it went black on start-up, but eventually (after 3-4 minutes) decided to boot-up.
I will disconnect the negative terminal and see if it resets.
As my first domestic vehicle/GM product I have to say I love the truck, but as a company they cut corners and struggle with the details (the devil is in the details). The intellilink system in the 2014/2015s sucks - they must have known this in the lab - there's no need for this in today's world.
Screen%20Shot%202017-07-12%20at%2022.13.
You should be able to hold the section with the presets and drag down pulling everything down into the default position. Your current display allows you to have like 15 presets to view where if you drag that display down it will be back to just viewing 5
Thanks Thereed! That worked. So strange that GM would even allow you to do that as it looks like $hit and serves no purpose. Regardless, I appreciate your help all fixed.
haha I had this happen too when I bought my truck. Thought I screwed up the screen. I'm sure you and I are not the only ones to do this by mistake :)
Haha - yes super strange. Why would the software even let you do this ... it looks like $hit.
