Trouble accelerating
romanzo
Hey so I recently purchased a 2014 Silverado z71 with about 27k on it and for the most part it drives great, however I have noticed on occasion when I really hit the throttle the truck sort of lags before accelerating. Also it jerks sometimes when I hit the peddle lightly, like if I am in traffic or something. Has anybody had any similar issues with their trucks? Thanks!
Yes, this is really how the trucks drive, unfortunately.
I do a lot of my driving in traffic and experience the jerk that you are talking about many times/day.
I think it has something to do with 4 cylinder/V8 flex. At one point I had an engine programming recall when my truck was new to address this, but it didn't seem to help. The most annoying part to me is the lag in accelerating- haven't noticed it in Ram/F-150 of the same year.
Sounds like the AFM is in V4 and switches to V8 when you step on it. This is normal.
Well I guess I am relieved to hear it is normal and not something wrong. However I would like to get rid of this. Has anybody resolved this issue with a programmer such as the diablo intune i2? I've heard you can override the v4 to v8 switch with one of those amongst other things.
two easy ways to kill the v4 mode:
1). shift into Manual (M), then it won't go into v-4
2). buy a "range afm delete".
What he said
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 410 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
