LED/ Rigid fog cubes - radio reception
I have Led headlights and rigid dog lights. Both of them affect my radio signal alot. Like if I turn them off I get great reception. If I turn them on one by one it gets worse... why??
There is excessive noise being generated. Are you using the factory power plugs to supply your fog lamps or are you using a aftermarket switch?
Sent from my SM-G930P using Tapatalk
My LED headlights don't mess with my radio, but the HIDs I had on my Titan killed the little bit of reception my 50 cal bullet antenna allowed. It was pretty bad.
It's possible that your Rigid lights may have bad ground pushing noise into your system, or ground-loop with multiple ground connections.
Are you using their wiring harness with relay and switch?
Can you isolate LED headlights from Rigids on noise issue to determine which is causing issue?
I have seen HID's with bad relays or grounding cause noise in AM spectrum..
Good Luck !!
I had the same issue
The problema are not the lights, what is causing your interference is your relay, engaged it generates a magnetic field that interferes with your antenna
Nothing, Absolutely nothing to be concerned about
Are you using the Relay that came with the Rigid Lights? If not, try changing it, see if it goes away :smash:
    White.6.2
    White.6.2
  • Who's Online   3 Members, 1 Anonymous, 438 Guests (See full list)
