Mirror cap removal
I have the DL8 mirrors on my Sierra that are colour matched to my truck (Stone Blue).
I found a set of DL3 mirrors that I plan on installing on my truck. The DL3's have a chrome cap. I want to swap out the chrome caps for the blue caps from my original mirrors.
How do the caps remove from the mirrors without breaking any of the retaining tabs?
I did a search but only came up with a couple of posts where the service manual says to pull up and forward. Some guys said they tried following the steps only to break the tabs even though they were extra careful.
Has anyone removed the caps without breaking the tabs?
Chrome caps are more brittle. I have removed about 10 sets. Of the 10, only two came out unscathed.
Don't do it. Color matched looks so much better and the Sierra blue is damn nice looking
He wants to take his color matched caps and swap them onto the DL3's.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 659 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
