C-10 ball joint install
I'm installing new upper and lower ball joints on my 1968 C-10. I'm not sure my spring compressor will shorten spring enough to get ball joint nuts started.
I can't use my floor jack to push lower control arm up. Motor cab off no so no weight and jack will just pick truck up.
Any ideas?
  • 3 months later...
Any ideas?
Are you using the threaded type spring compressor, rent a second set from autozone and use them to compress it even more ? You could buy lowering springs for like $100.
I got it..
