Tire rub
I just put on a set of 35" tires on my 2017 Sierra.
At full turn the tires rub a bit on the inner front of the wheel well liner.
What is the liner made of? It doesn't look like plastic.
I was wondering if it's possible to take a heat gun to the area where the tire is rubbing and "shape" it to give it more clearance?
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,016 Guests (See full list)
