Harbor Freight Shop Crane
The length of the 2 legs aren't wide enough to put engine crate in the middle to pull the new engine out. That's the only issue I have with it. I am looking at one right now as we speak. I have a dragaway 2t at my home shop I bought off amazon a while back. It works really good and is able tofold up the legs and put it in the corner and take up little space. That's why I like it. http://amzn.to/2jhfmDE
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
