I have 1979 GMC 1500 and I am trying to find what these two RPO Codes mean (no luck on Google)
W85
32D
I have decoded the rest of the codes on the glove box door, but these two were not listed.
Thanks,
Here is what I have....
RPO Codes:
A01        WINDOW, TINTED, ALL SHADED, W/S
B3J         EQUIPMENT DIESEL
C60         HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DG4       EXTENDED BELOW EYELINE MIRRORS
E63         BODY EQUIPMENT, FLEETSIDE, PUBX
F51         SHOCK ABSORBERS, FRT & RR, HD
F59         STABILIZER SHAFT FR,
G50        SPRING REAR, HEAVY DUTY, VAR 1
GQ1       AXLE, STD RATIO
LF9         ENGINE, DIESEL, 8 CYL, 5.7L
J55          BRAKE SYSTEM, HEAVY DUTY
MX1       MERCHANDISED, TRANS, AUTO PROVISIONS
N33        STEERING COLUMN, TILT TYPE
NL2        FUEL TANK, AUXILIARY
N67        WHEEL, RALLY TYPE , VAR2
P13         CARRIER, SIDE MOUNTED SPARE WHEEL
U63        RADIO, AM, MTR
UF2        LAMP, CARGO
W85       ???
V22        GRILL RADIATOR, CHROME
XCA        TIRE FRONT P205/75R15-97S WOL R/PE ST TL ALS
YCA        TIRE REAR P205/75R15-97S WOL R/PE ST TL ALS
YE9         CONVENIENCE PACKAGE, COMFORT & DECOR LEVEL #3
ZCA        TIRE SPARE P205/75R15-97S WOL R/PE ST TL ALS46L
Z49         EXPORT CANADIAN MODIFICATION MANDATORY BASE EOUIPMEN
ZY3         COLOR COMBINATION, SPECIAL TWO TONE
17U        PRIMARY COLOR, EXTERIOR, LT SLATE MET (91)
46L         SECONDARY COLOR EXTERIOR, DEEP SEA GREEN MT (99) OPEL
32D        ???
Besides the fact that I am jealous of the truck, I dont know enough about them to figure those out.  My only advice would be to check out as many sources as you can.
The RPO Code Master List I have shows:
W85 - EQUIPMENT, MISC EQUIP FOR INDONESIA (INDONESIA CONTROLLED)
32D - TRIM COMBINATION, CLOTH, MED DK CASHMERE (D) (04)
Sound like these apply to your '79?
Thanks Bob!
Not sure what equipment for INDONESIA would mean being a Canadian Built pick-up.
The interior is a green cloth, I wouldn't think you would call that cashmere, but I suppose its possible.
    Selfman
    Selfman
  • Who's Online   3 Members, 1 Anonymous, 523 Guests (See full list)
