Just Passed 2 YRS on GM-Trucks
Ravenkeeper
Hey, just stumbled across this section, and hadn't posted in it, yet.  So, "HELLO!!!"
Chris
CB callsign: Desert Raven
CB Channel: 19
2015 Chevrolet Silverado 1500 LTZ Z71
Purchased ADD-ONs:
- Tonneau Cover
- Nerf Rails
Completed MODS:
- All FWD facing white ON with HIGHs
- All rear facing white ON with REVERSE/CARGO
- Puddle Lights ON with UNLOCK/OPEN/INTERIOR-ON
- Deleted AM/FM Antenna
- Bed Divider
- CB/Scanner Install (Center Console)
- Tow Hitch BRAKE Light (mod'd brake/tail light)
- Phone Holder in pocket, left of steering wheel
Planned MODs:
- Front Tow Hitch
- LED Light Bar behind Grill
- Another Bed Divider
- Hidden AM/FM Antenna(s)
- Tint across top of Windshield
- LED Reverse/Cargo Lights
- RED LED Brake/Tail Lights
- BRIGHTER HIGH Beams (burn your eyeballs out of your skull, from beyond the horizon)
- Train Horn
- Dual Dash Cams (forward/rear)
- Brake Light Switch
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
