broke again
RP53
well for the 3rd time in less than a year my truck is in the shop, this time driving down the road check engine light came on, then started blinking. i had already scheduled an appointment for the steering recall so i was going to the dealer,  he  said the coil was bad and also the plug wires needed to be replaced, the truck has 57000 miles on it . the same thing happened at 27000 miles. this truck has been in the shop 4 times for electrical issues since it was new.  so this morning i started conversation with  GM concerning a buy back as i really think i have a lemon
I hope you guys can work something out.  I would not want the truck if mine were doing that as well and with that history.
as do I,  sad part is my wife is scared to even ride in the truck after the several hours we spent waiting on a rollback the first time it broke
    zibzer2
    zibzer2
  • Who's Online   4 Members, 0 Anonymous, 739 Guests (See full list)
