Engine power reduced, CEL
Lilcanadian
Was a cold day today, had a weird issue I'd like some opinions on. Truck was plugged in over night, started fine this morning. Parked at work for the day, again started fine leaving work. Drove to the store and left it parked for about 15 minutes, tried to start, cranked but would not start, got an engine power reduced message on screen. Let it sit for about 5 minutes then tried starting again, this time it started, everything was normal but check engine light stayed on. Called the dealer and the service guy said it's probably just the battery, my thoughts on this is if it's the battery why would it start if I let sit a few minutes and tried it again?
Any thoughts on this are appreciated, thanks.
1 hour ago, Bxnanaz said:
If it cranked over at a normal rpm when it didn’t start, it’s not the battery.
Yeah cranked normal just no start, going into the garage next week, still under warranty so hopefully they can find the problem and fix it.
  • 3 weeks later...
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 765 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
