Fab Fours Bumper
dons62
I am going to install a Fab Fours front bumper on my 2016 Colorado Z71. I am planning on not using the factory fog lights. I want to install a 20 inch LED light bar in the center slot of the bumper. Does anyone know if the factory fog light wiring support this if I splice the light bar wires into it.
    President Roberto
    President Roberto
  • Who's Online   3 Members, 0 Anonymous, 294 Guests (See full list)
