Activating wire harness w/o to package
I just bought a 2003 2500HD. It had every option I wanted except the tow package. I noticed the wiring plug was there by the spare tire, but when I plugged it into the adapter from my 2002, no lights. Any body know how to activate this harness.
Also, is that all I'm missing w/o the tow package? I have heard that I am also missing an aux trans cooler? Looks like one under there to me!
Thanks
James
'03 2500HD Duramax/Allison
JIM............Heads up! Gm changed the trailer wiring set up on
the 03s. Your old plug from 99-02 trucks will not work !
Cheap old GM don't even give ya the hookup plug on 03s.
You have to go to the stealer and buy one SPECIAL for
your 03! :thumbs: ......................geo
Found out from the the parts guy at one of the local dealers that if you have the brake controler wiring harness from 00-02 all you need to do is switch the two wires labeled A and D on the plug with each other and it will work on the 03's. You can take the wiring harness plug apart be removing the blue pin lock clip and taking a small screwdriver and push out the two wires in position A and D and switch them (no need for the screwdriver to put them back into the plug) and replace the blue pin lock clip.
Ray
2003 2500 HD
:seeya::D:lol::cheers:
