Camlocker Tool Box - $350
Camlocker Truck Tool Box for Chevy / GMC 1500. Will fit 2014-2018. Purchased new 6 months ago from Caitlin truck accessories for $574. Excellent condition and selling because I'm selling the truck.
Model: CAMKS71UNLPMB
Deep box, matte black diamond plate, cam locking mechanism, carpeted inside and shelf tray.
No Shipping and willing to meet within reasonable distance in Northeast Florida.
$350
0cfebf398a3ae1a1e80a1e3b42d76e59.jpgbbc848cbb9fdbb72c1ba82a4ce18696a.jpg0a0da8a64fb676e0e0591be4e1612d34.jpg584c1a23347a926f92460c281f48788a.jpg6dcb26729bddcf8a9a02393f0791cb3f.jpg0ce1d8ac5e831084cf3f49de27d171ba.jpg7187c07d013291cf14a29ddf1e6b9e23.jpg
$350
Sold!!
