2014 GMC Sierra Oil cooler line leak
Yesterday I noticed a leak in what I believe is the engine oil cooler line on my truck, It looks like the crimp is failing where the hard line is crimped to the rubber hose.  Has anyone else had issues with this? currently it just looks like a very slow leak so I am not very worried but I will address it when I get a chance. The truck was purchased in Nov 14 and currently has 28000mi My initial 3 year warranty has expired but I have an extended warranty to 5 years 50000mi
Don't know if its common but the dealer just replaced that on the 14 High Country I just bought.
4065470 - Engine Oil Cooler Hose Replacement
Rich
I've been told by 2 different dealers that my 2015 Yukon lines are leaking.  They look just like the pictures you have, residue on the line but no drops on the garage floor.  I've got 106k miles on mine, but I'm trying to avoid worrying about it until the leak is more significant (actually produces drops or is affecting fluid levels).
Yeah my guess is that it is just a bad crimp, there is no residue further up the rubber line and no residue on the hard line where it enters the block so the crimp is the only place I can figure it is leaking.
Sent from my LGLS991 using Tapatalk
Very common problem, even on older generations. Mine have been "leaking" since I've owned my pickup. Currently 130k miles. I plan on cutting the hard lines by the crimp on both ends, flaring the hard lines and putting hose clamps on instead of another set of crimped lines that will eventually leak. If it's covered under warranty I'd have the dealer replace on their dime, but the fix I plan on doing is maybe $20 in parts.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 715 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
