The real way to move snow
Jpshostr
I tried this post earlier, but deleted it when the pictures didn't show up.
This is how you move large amounts of snow.  Send 185hp through a blower while seated in a nice heated cab listening to the radio.
Now that's a cool snowblower.  :D
Zane was bragging earlier this winter that he had a badass snowblower, I'd like to see if he'llpost pics of it and we can compare. :D
Kind of a wussy looking blower if you ask me!!!  Try a Black Max behind a 8410 JD and front wheel assist!!!  Cover that puny thing up in about 20 sec.
I must confess, this blower is only rated for 65hp. :0   Funny how one can snap shearpins with ease if you aren't careful. :D   Only reason we have this tractor on it is that cab feels REAL nice instead of snow blowing down your neck.
If I had to blow snow in reverse as well as I used to back my boat, my mailbox would be toast.
Ya know, last year I sent our mailbox across the road.  Snowplow knocked it off the post and it was partially buried.  I watched it get sucked in and then shoot out the back, luckily it didn't go up the chute, also quite lucky no cars were going past cause it went out like a rocket.
JP, you have the wierdest toys :D Looks like one wail of a driveway.
Weird toys?  I think they are awesome. :D   Only problem is they cost lots and lots of money. :D
The driveway is pretty long, and with fences along both sides it'll drift solid with only a 2" snow if there is any wind to speak of.  In the picture below you can see the upper half of our home driveway.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
