"service advanced brake system"
Had "service advanced brake system" pop on my dash briefly 2 times yesterday. Both times I was rapidly pushing the brake pedal several times to get the front end to bounce.  the brakes seemed fine, abs seemed like it would activate, then the pedal became stiff. The message then goes away, no dash lights, and the brakes seem normal.
I did just install a leveling kit prior to this. I was bouncing the front end with the brakes to get the suspension to settle.
I know the alignment is off, going in this am to have that done.  I did not overstretch brake lines or ABS wire when installing the kit. I do have magneride shocks, but used extension brackets and the wires are reconnected and not stretched.
is that "service advanced brake system" message just because I was rapidly pushing the pedal or is there another problem?
thanks
Probably a great question for the dealer when you take it to them to get the alignment done.  I would think they could pull the codes of it real quick.
    MANGOAL
    MANGOAL
  • Who's Online   1 Member, 0 Anonymous, 479 Guests (See full list)
