Leather help
I have 50k on my 2014 1500 and the drivers and passenger seat already looks like ahit. I am having nightmares of the old 1997s that still drive but have half a drivers seat because the leather and foam have been eaten away. I am trying to drive this truck for 10 years. What can I do to ensure the leather goes the distance. I have conditioned it with Hendricks but in my opinion it hasn’t helped. Also what effects leather? I’m in NC and the sun can be brutal, although I do have a tint strip and 20% I’m considering buying a reflector for the front windshield. I also have Weston sidesteps so I’m not sliding across the seat. 7ee024c852e32c7e8f3bb2c38026e4dc.jpg39bc6fee4fc996af28aeb58f80bf8923.jpg2add8cf1c7a50555ab345545f04278b2.jpg
We just took the wife’s grandparents 2017 Suburban on vacation. They bought it new and now has 5k miles. The seat looks like that. I was really surprised! I am judging this based on us buying their old 09 Suburban. The seat in the 09 looks fine.
For tips on leather care, hit up the autogeek and autopia forums. There’s tons of info there to research. But from what I’ve read, most (if not all) leather interior products are a tanned and dyed hide that has been further treated with a synthetic top coating. Old school leather conditioners and treatments end up just sitting on the factory coating layer rather than penetrating.
The new approach is to thoroughly clean the seat with a diluted all-purpose-cleaner (APC) or steam, then top the leather with an additional coating or protectant chemically designed to bond to modern automotive leather.
What to do about already damaged leather? That can be tricky. OP, your seats look about like mine (roughly the same age and wear). They’ll benefit from a good cleaning to remove the surface grime and oils (and even the hendrick stuff that’s just sitting there). That’ll get you back to a somewhat factory look, except where the leather has been burnished smooth and shines a bit. Pick one of the newer leather coatings to apply and follow the instructions to the letter. You will at least have restored the seats to a baseline that you can maintain from there. Really rough seats, on the other hand, might need a look from the dealer service department if you’re still in warranty. They shouldn’t wear that fast.
As a last resort, there are some excellent aftermarket leather seat replacements. Katzkin, for example, seems to be very popular. I’ve seen them first hand, and I might agree that they’re nicer than factory.
Good luck!
M.
Also, look into getting a drivers side entry assist handle. It’s a gm accessory, found in any online parts outlet, your favorite auction site, or the dealer parts store. It will help keep the seat bolsters from taking a beating. Takes about 15 minutes to install.
And I think (but double check first) the part is the same between GMC and Chevy, pickup and SUV.
M.
    DaleB
    DaleB
  • Who's Online   3 Members, 0 Anonymous, 1,109 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
