Bad Fuel Milage
I bought a used 2008 Silverado 1500 2x4 4.8L a few months ago. It has  slightly larger tires and a flowmaster with 2-3/4" before it and 3" after. everything else is stock. It has 113,000 miles on it. The MIL is not on, I checked anyway, no codes. started looking at all of the sensor readings while driving, they all look good except fuel pressure. Key on, not running I get about 64psi. It will hold that presser (no bleed down). After I start the engine the fuel pressure slowly drops to 42-43PSI and stays there. Idles smooth and runs great.
The dealer I bought if from was about 2 hours away, (most of it interstate). That trip and a little while after I was getting about 18MPG. Now I get really bad mileage.
14.1 @ 60MPH,
13.1 @ 65MPH
10.9 @ 70MPH
8.4 @ 75MPH
All of the above numbers were taken on flat, level ground.
Any ideas would be greatly appreciated.
Time for new cats.  Do you have access to a good scan tool like the Tech2?  You'll want to check for codes in memory and your Long Term Fuel Trims.  A bad vacuum leak at the heads/intake can cause this as will worn cats.  My mileage steadily decreased right after I bought my truck but did not throw codes until the end.  Replaced the Y-Pipe with the Magnaflow and all is well.
I get better mileage than that on E85!  Your fuel pressure is fine.
