Part Number 15713205
Hello all,
It seems part number 15713205 (Left side cowl plenum drain) has been discontinued. You can still get the right side one, but not the left side. Anyone know of a good place to find discontinued parts (other than eBay), or does anyone have one laying around they would like to get rid of?
Thanks, Chad
7 minutes ago, starman8tdc said:
  Why not buy it on eBay?
I looked there, but they did not have any.
  • 3 weeks later...
On 7/20/2018 at 3:25 PM, telo said:
Look into this. Maybe you'll find it through this
http://oemcats.com/oem-parts/15713205.html
Also have you checked with a dealer to see if they can locate one at another dealership?
Yea I checked there and none of the dealerships had one, as it is listed as discontinued.
On 7/20/2018 at 10:43 AM, starman8tdc said:
Yea, I was wanting to try and find new if possible, but I am thinking a salvage yard may be the only place I can find it.
What Kind of truck is it? I am showing 15713205 as a good number but as a valve?
I do see that it is discontinued now. I will check our pick and pull tomorrow and see if there is one there.
Thanks Chris. Were you able to find one?
    Dom Colussi
    Dom Colussi
  • Who's Online   3 Members, 0 Anonymous, 551 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
