Sierra 1500 vs classic
Can someone tell me the difference between the 2006 GMC sierra 1500 vs the 2006 GMC sierra classic? Which do I have? Here's a pic of mine.... Sorry trying to get some center wheel caps and it's very confusing lol
Hmm.. 2007 model year is when the GMT-900s came out to replace the GMT-800s.. But in 2007 there were still some of the GMT-800s made which were called the "Classic" If I remember right.  I wonder if they sold some GMT-900s in mid to late 2006 and listed them as 2006.. in which case the classic would be your style, the GMT-800 style.
Why did you put the chevy taillights on though?  The GMC taillights looked much better in my opinion with the amber turn signal that stayed with the GMCs from 1999 to 2007.  Chevy went with the all red with round accents in 2002/2003-2006/7.
I've always like the silverado taillights better. They were a direct fit. The ones I purchased had the harness so it was plug and play.
The early 2007s would be the "classic", GMT-800 body style. 2007.5 is the GMT-900 body style. They did the same thing in 1999, the early ones were the 88-98 body style and the 1999.5 was the 99-06 GMT-800 body style. See attached photo, 2007 "classic" on top, 2007.5 on bottom
You have a 2006 plain and simple. No distinctions. Split occurred in 2007 with the split from GMT 800  and 900 series. 2007 & 2007.5
You never posted in your other thread how you cured your ECM and water infiltration issue. Post back for others with same issue to see
