Checking oil after driving
scagle777
I usually check my oil on a pretty regular basis. I just bought a 2014 with 32000 miles. I drove it approximately 15 minutes this morning, and decided to check the oil. After I let the truck sit about 45 minutes, I checked the oil and it was a bit low. The engine temp was around 170 degrees at the time I pulled the dipstick. Could the oil still be draining into the oil pan? Also, how low does the oil need to be before it throws a light? Thanks.
The oil in these engines is just slightly thicker than sewing machine oil if you're running the 0W-20.  After 45 minutes, the level you got was probably accurate.
The time my oil pan was leaking on mine, it threw the low oil message when it was about 2 quarts low.
You should get an accurate indication on the dipstick within a few minutes of stopping the car.  When the oil is hot, the viscosity is not much thicker than water.   If you pull into your driveway and go take a leak, when you return to check the oil, the dipstick will read about as close as necessary.   It's not like draining the rain forest of South America. The longest path to drain to the pan is but a few feet.  Don't get too worried about a little low indication, unless it's loosing oil at a high rate.  I don't even check my oil anymore.  It doesn't go down much over an entire change period and it has a low indicator on a very large 8 qt reservoir.
I’ll definitely check it when I get off work. This is the first time I’ve dealt with the ecotec engine as well as 0w-20 oil. Thanks for the info
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,414 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
