fog and headlight leds
4 hours ago, CO-Stark said:
Yes. This. I'm thinking hard about getting into a 2500 Duramax, and I know it's stupid, but the lighting situation bothers me. On my 1500 LTZ, the only non-LED I've found inside or out is in the 3rd brake light (also frustrating). Unless I'm wrong, I haven't seen the HD trucks with nearly that many stock LED on them, even in High Country/Denali... just surprises me that they made such a change for the '16 1500 but didn't do it for the big brother.
Could not agree more,
It is literally the only thing I hate about this truck.  I will update in time...  I bought this to tow my 5th wheel which is a pig... about 15k.  Just went a month ago and picked it up 300 miles away and was surprised how well the 6.0 handled the weight.  It did have a hard time shifting and holding 5th gear so I added a pro-charger which boosted the hp up about 175 which brings it to about 530 give or take. Now she shifts like a dream!!   I just didn't want a diesel.  This solved that problem.  Also my mileage went up... Go figure.
  • Replies 62
18 hours ago, jerseytaylor said:
thats not an HID problem. thats could be a housing/projector issues.
Someone already posted a TSB for the factory HID bouncing and flickering and GM stated it couldnt be fixed since its the flame (arc
) bouncing. It's annoying as hell. That's why I want to replace my headlights and fogs with some nice LEDs, but I have no idea where to buy from. I'd like a plug and play setup.
i replaced mine with 16-18 SLT/Denali 1500 LED assemblies. I'll be honest though, compared to a projector and HID, the output is subpar....but, the headlights look so much more modern now though so...lol
theretrofitsource.com
On 2/20/2019 at 7:28 PM, cdh027 said:
I just want to put a set of matching LED's in my factory headlight and foglight housings.
btw...to clarify...are you certain youre not confusing the "bouncing" cutoff line of light with what you think is them shaking? Not trying to insult your intelligence man but Ive seen situations in which people who werent familiar with a cutoff line thinking something was shaking and broken (these were people who were just used to old school reflector housings throwing light everywhere and not used to seeing a clean line of light projected ahead. Bumps and dips in the road will make the line "bounce"
Interesting point. I'll have to get back to you on that. The truck is in storage for the winter, so it may be a while.
this is an extreme example and for headlight junkies its to die-for lol, but the HID and projectors in our Sierras produce essentially the same effect. it may take a minute to get used to coming from a halogen bulb and reflector assembly, but it is a great thing to have as it truly is the light you need actually being where you need it- out in front and on the road. good luck man!
  • 2 months later...
Just tried a set of LED's made by Heise. H11 low beams went in OK but 9005's were iffy fit on my 2015 1500.
Passenger side dust cover on high beam is a no go so I am pissed as I was told these are plug and play.
I'll check them out at night and see if rigging something is justified but may just go back to halogens for high beams as I have aux driving lights.
Still, pissed off that these manu's make shit that does not work. Heat sink is too long for cover to fit.
Crap. Avoid this brand.....
Get these AuxBeams.
https://www.amazon.com/dp/B07JB8517F/ref=cm_sw_r_cp_api_i_NsRVCbTPG2EQE
Wow. Very cool. They look almost the size as the originals! (Halogen)
Any idea on quality?  I will order some as that's a way the ones I got should be...
Quality is decent, just as good as anything else you can get for $50-$60.
I'll try a set. The ones I got were $129 EACH.....and they don't fit on passenger side high beam. (9005)
Jeez thats expensive. You guys really need to give pure white HID's (4300-5000k) a shot. these LED bulbs will never put out the same output as they can.
They are. HID's are going away and LED's are the future. That said, I am not impressed with the output of these as they claim 6000 Lumens each and there's no way.
I have a two sets of Rigid auxillary lights, spots and floods and they're rated at 3500L's each and they smoke thses. No contest.
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,414 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
