So I went in to have seatbelt tensioner recall done and the backup camera updated so that it doesn't wash out at night with the reverse lights. About two weeks prior to this my backup camera became fuzzy/Staticky.
Just a heads up to anyone that has this static problem, it was caused by a cell phone charger in the console port. Not the usb ones but the 12 volt charger port.  They showed me the service bulletin and sure enough when I use the cheap CVS charger in that spot the camera gets static.
Talk about an easy fix. There was tons of talk online about camera wire, moisture etc. Nope. Cheap charger.
Just FYI for those with same problem.
Jim
Edited by jcgib81
  • 1 year later...
  • 1 month later...
Mine has turned from HD into something that has a wired antenna on the back of the TV.  I don't have any of those chargers in my truck.   I will probably check it again and see if it resets.
I had this same issue and it was my after market LED headlight bulbs. After getting the camera replaced and it not correcting the issue I for some reason thought to turn off the headlights and check it one morning. That was it. Put the factory bulbs back in and perfect !
  • 11 months later...
Hi,
I know this is kinda an old thread, but I wonder on a Colorado with a Leer tonneau cap on, maybe the wiring from that is causing my rear camera picture to be fuzzy?
    C. Hart
    C. Hart
  • Who's Online   3 Members, 1 Anonymous, 464 Guests (See full list)
