2014 Silverado V6 4.3L 1500 double-cab Z71 4x4 LT Model - 75,500 miles
Check engine light came on about 2 days ago on my way to work. Stopped at the auto parts that afternoon when I went to lunch and I had the P06DA - Engine Oil Pressure Circuit / Open code.
Called the dealer where I got the truck. They want me to bring it in for diagnostics, which is fine. But I always try Google first as I have 0 trust for sales, service and mechanics. I've read a few things about this on Google, but seeing it on Chrysler 200 3.6L's and Silverado 5.3L's. Mine is the 4.3L. Wondered what it could be, doesn't seem to be a lot of solid answers.
Service dept. said it could be the sensor at around $120 to fix, no biggie.... or the oil pump at $2k, a bit more of a biggie. She also made sure to state the obvious, that it's not covered under warranty, because nothing is ever covered under warranty.
If it's the oil pump, is this repairable myself? If I need to remove the motor, or it's a 10+ hour job, then it's a no-go for me and I'll be crying my way into the dealers service department. I read about solenoids, but seems to be on the 5.3 - service lady said she sees nothing on a solenoid, only a sensor or a whole new pump.
Again, I will be taking in to place on diagnostics, unless I'm missing all the right Google results...
I will try to update as I notice/find out more things, I will also try to provide as much detail as possible in case this appears for anyone else.
***Update 1***
I should note, everything seems completely normal. Including engine oil pressure, fluctuates from 40's to high 50's (upwards of 60) depending on rate of acceleration, which it's always done as far as I can remember (original owner) - oil pressure is actually about 45-50 when sitting idle, highway acceleration is around 60-70 - city acceleration is around 55-65. doesn't go above 70, doesn't quite reach 70 either, more like high 60's
***Update 2***
Went ahead and got an oil and filter change as it was close to due. Nothing noted from the garage, pressure was fine and no metal shavings or anything in the oil. Also, I've been monitoring engine temp and other things I can think of. No changes in engine temp or anything else suspicious. One thing to note, remote start no longer functions due to the check engine light. This is a safety feature due to a check engine line appearance and completely unrelated to the P06DA code issue.
***Update 3***
Might be being paranoid, but I'm kind of putting myself in that overly worried state. I think there's a bit of a whine, kind of like a power steering whine. But again, I'm trying to be overly cautious, so it might be completely normal, I can't recall now as I'm trying to look for anything abnormal and might be over thinking it.
***Update 4***
Diagnostics test scheduled for this coming Tuesday (4 days from now) test will likely take all day, I will update with the results afterward. Decided to monitor mileage and the trucks ability to shift in and out of V4. Truck no longer shifts into V4, stays in V6 always. Might also be a safety feature due to the check engine light appearance? I'll find out more at the dealership on Tuesday. Unrelated, following behind a semi on the highway on my way to work and a rock (or something demonic) shot up pretty hard and chipped my windshield. Called insurance (USAA) and they sent out Safelite. As soon as they put the machine on my windshield it cracked pretty bad.
Edited by dilerious
**I added this to the updates in the original post, I wrote the pressure numbers down incorrectly as I was trying to go from a visual memory while sitting at my computer and trying to remember what the pressure gauge looked like in my head.**
Edited by dilerious
Took the truck to the dealer, they called about an hour later and said they needed to replace the engine oil control solenoid. The great news here is it’s not the oil pump and IT IS COVERED UNDER WARRANTY. I’m ecstatic because the solenoid is located inside the pump and is rated as a 14+ hour job even in the dealers service department.
best news I’ve had all year.
I’ll update again once I pick up the truck.
Picked up my truck today. Read through the work order, they ended up replacing the entire oil pump.
also read that there’s an issue with the main wiring harness that seems related to the oil pump issue. They replaced that entire wiring harness as well.
they listed having to drain the AC system to replace the pump and had to refill that as well.
couple of things to note.
oil pressure should idle around 40-45 and not really go above 60 when accelerating even when on the highway.
I’ll try to update in about a month.
  • 3 years later...
So your oil pressure never goes below 40 on your 4.3? I had the code P06DD which is very similar to the one you had.  My problem was the thermostat was stuck open and temperature was never going above 180. Once I replaced it the temp went up to 210.  Before I replaced the thermostat my oil pressure stayed about 40-45 at idle and went to 60 and a little over when accelerating.  Now it idles about 60 on cold start up, comes back down to 40-45 a few minutes after start up, but once it gets hot the oil pressure drops on back to 20-30 at idle.  My pressure goes past 60 near 70 when I accelerate.  I was told that was the correct range for this truck that if it was never going under 40 psi when it was hot that there was something wrong. This fixed my issue for a little while, now I find the code coming back every now and then as a pending code. Before I replaced that thermostat every time my truck went into v4 it would immediately switch back to v6 mode and throw the pending code.  Now I have drove over 500 miles with it going into V4 mode like it should, but sometimes (seems like its when I'm accelerating and the oil pressure is over 60) it will stop going into V4 and I will see a pending code P06DD and I clear it out, and then I won't see it for a while. If yours is never going past 60, makes me wonder if that's what is causing my pending code when mine goes past 60 psi. I know its been 4 years since you posted this but hopefully your still around on here :)
    tblt44
    tblt44
  • Who's Online   5 Members, 0 Anonymous, 641 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
