First post here in a long time but just recently picked up a 2005 GMC 2500HD 6.0 with 183k miles and 4l80e transmission.  Vehicle is really clean but have come up with a transmission issue.  When cold the transmission shifts into OD on the highway no issues.  When the transmission gets up to operating temp it will not shift into OD, it sits at 3k rpm at 70mph.   I did a stall speed test and it comes up to 2400rpm (believe stock is 2600) unsure if that is a real issue only 200rpm difference so don't believe it is the TC.  When cold or warm the transmission shifts smooth as anything just when warm will hang 3rd.  Checked fluid and it looks clean, not burned and full.  Wondering if its worth changing the fluid/filter/shift solenoids and go from that point or just bring it to a shop.  Not sure if the wrong fluid was used and if that would even cause the shifting issue when warm or if it is just the TC that needs to be replaced.
Thanks!
Edited by spiGini
Just an update since nobody responded.  Little more information on my issue which starts when the trans temp reaches above 150 degrees.  Below 150 degrees the transmission has no issues shifting into 4th or 4th gear lock up.  Above 150 degrees it will not shift into 4th but has no issues shifting 1-3.  My thought was the fluid was getting thinner but didn't know what or where it was going wrong.  Dropped the pan and checked all of the solenoids and everything was in spec for ohms reading.  Thought it could be the feed limit actuator that is known to bore itself out (still unsure if that is damaged but ordered a whole new valve body with upgraded transgo feed limit).  So in preparation for the new valve body to arrive I decided to take out the old one last night.  When I dropped the valve body along with it came half of the 4th bolt or 4th clutch bolt.  The other half was stuck in the transmission.  I assume it was over torqued at one point causing it to crack and when the fluid gets thin it escapes through the threads instead of providing constant pressure to the 4th piston.  Had to use a tap and screw to get out the half stuck in the transmission.  Now not sure if this is the exact thing causing the issue but I assume it will be.  So a $5 part was causing me to lose 4th gear when the transmission reached over 150 degrees.
Just wanted to update the thread in case anybody has issues later on and doesn't know where to start.  If everything checks out with the solenoids i'd take a look at this bolt.  And I'll update this weekend after I put in the updated valve body and new 4th bolt in to verify everything is good to go now
Edited by spiGini
  • 2 years later...
    Tonwantonga
    Tonwantonga
  • Who's Online   4 Members, 1 Anonymous, 829 Guests (See full list)
    • What I think you're saying is there is supply here at home, and in Venezuela, and we could ease pricing if only it were favorable to do so.   Well, yes?   But that's not the current market. Supply isn't what could someday exist, if only, it's what producers are willing to produce and sell at a certain price point.   The national price of single family homes would come way down if we'd just slap together a few million homes this summer.   RAM and GPUs would get a lot cheaper if we just set up some factories to produce a bunch more and stopped using it to build out AI data centers.
    • The turn signal/multifunction switch is faulty.  I've seen a few of these go bad at work.
    • I am experiecing the same issue, I have gone in the setting and disabled rain sensing function but I am still experiencing this. Whe i use my turn signal they will redomly turn on. Sometime they stay on and others times we swipe 2 or 3 times and stop. Its super anoying, escpecially after a fresh wash. Anyone have any advice? . rain-sensing function, but I am still experiencing this issue Sometimes they stay on, and other times we swipe 2 or 3 times and stop.It's super annoying, especially after a fresh wash.When I use my turn signal, they will randomly turn on. I am experiencing the same issue. I have gone into the settings and disabled the rain sensing function, but I am still experiencing this.
    • If we actually used any significant amount of that source in the USA then I'd agree but we don't. We've had that discussion before. We drill and pump more than we use. Thing is, we sell. We export. Gas and Crude. It's more profitable so any shortage here is self inflicted and LEGAL.    I worked a gas plant that has multiple fuel sources available and I worked in the furnace and boiler plant in that facility. I'd had days we swapped fuel types four times in a twelve hour shift which isn't done on supply but on margin. Two of the fuel sources are internally generated. Tail gas and DAK, both of which are sold as well a consumed. We always had more than we needed to run the process but we chose the fuel that produced the best margin not bought at the cheapest price always. A good bit of math to that and back in the time that was done on a slide rule.     I worked the Shale Oil Semiworks of Chevron Research and CONOCO Research in Salt Lake City. That process never went into production although it was very successful. Why? Did we lack oil bearing shale? Nope. Price of crude never made the margins work. That was in the late 70's early 80's. Remember history? What was happening then was a reaction to that situation. It didn't drive it. If so then it's easy. This isn't a supply and demand thing. This is a profit and margin thing and AI rules that now.    In no refining situation that I was ever in would a bomb hitting a well anywhere in the world 'instantly' interrupt or even distress the supply. Most plants have more than a months worth of crude in the tank field and more in pumping stations. That yo-yo could play out over days, weeks and maybe months and have zero impact on plant operations. How many times has this been off and on in the last few months? These people and not stupid. These plants measure down time in hundreds of thousands of dollars per day. They are not sucking fumes or waiting on the next truckload with baited breath. Besides, as I noted, they are for the most part 'vertically integrated'. They own it from the dirt is sits in to the delivery rack and sometimes to the pump. It has a HUGE shock absorber built in. When production suffers, refining wins and when refining is winning exploration is killing. The rest of that crap in the news is a 'news cycle'. Government dipping in to reserves? Oil is stealing their milk money. There's a reason Chevron abandon Venezuela infrastructure and it had nothing to do with security of US citizens. Nationals run those plants. it has to do with MARGINS disappearing to corruption. They are in no hurry to return. Is there supply there? Oh yea. More than enough to offset what is bought in the middle east. Just isn't ???? Profitable.    We have supply. There are places in Illinois you can drive a pipe into the ground and run your homes natural gas furnace on it.    A refinery fire will gum up the supply works but not a localized war where the market is using a limited supply from. Now Europe, that's something other....
    • $4.00 a gallon here now.   Diesel nearly $5.00 again.
