My condenser went out on my 14 and it stopped my seats from cooling and AC from working... Next I'd be careful of your engine oil levels... Like you I took really good care of my truck and just broke 50k as well. My truck has been burning oil like a big dog. 7k to fix.... So I got rid of it since it won't get better.
