Clean battery connections by loosening and removing them.  Clean both cables and battery posts.  Put cables back on and tighten.  Remember to remove negative first, and to put positive back on first.
You may need to boost battery if 8t is dead.  From your description it is either a bad connection on battery or dead battery.  Take a look at the ends of the ground cable.  Look for a split in the plastic around the cable at the engine end for any corrosion in there.
    appletrav
    appletrav
  • Who's Online   6 Members, 0 Anonymous, 571 Guests (See full list)
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
