Is the hood off a 1993 Chevy truck identical to a hood off a 1995 GMC Sierra 1500?
Sent from my SM-G960U using Tapatalk
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
