Hey all,
I've had a reoccurring issue with my 2014 Silverado 1500 Z71 in regards the the trailer brakes. Now in the second year of owning the truck and I realize that this problem only happens when it is colder outside, 40F or below I would say. I'm getting the 'service trailer brake system' on my dash and the chime along with it. It will pop up and chime anywhere between 5 to 30 seconds and will continue to do it for several minutes. On longer drives, it may stop for several minutes then starts to prompt the warning again with the chime. Very annoying. I had it at Chevy last year when it started and they said there were no codes in the system and couldn't find anything.
I've read several threads about this issue but none specifically mentioned that it only happens when it is cold outside. I've made a list of things to check that include checking the fuse under the hood. Check voltage at one of the posts by the fuse box. Dielectric grease on the trailer brake module connectors. Check for breaks in the wiring. Check brake fluid and pressure switch.
What throws me off is that this only happens when it is cold. Can anybody help point me in the right direction here?
Thank you
I had a similar issue with my 2014 2500hd...turned out to be the trailer wiring harness grounding on the frame.
Sent from my SAMSUNG-SM-G930A using Tapatalk
My 2015 GMC HD had a similar situation with the same message popping up. I found mine to be to be the control module that is back by the gas tank for the trailer / trailer brakes. Also you may want to check your wiring harness plug male plug on your trailer if it has a clamp on it with a 7 pin connector there might be something corroded or loose in there, I found this to be one of my problems as well.
There is a very descriptive YouTube video on how to find and replace the trailer brake connection module. The unit itself on eBay was 20 something dollars
  • 2 years later...
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
    • The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer.
    • My 2026 Silv. 1500 WT (reg cab/short bed/4wd) has the 40/20/40 with storage in lower middle seat as well as the fold-down center bolster/armrest.   With the dual glove boxes this is about as much storage as possible in a std cab IMHO. Bill
    • I have a 2026 base 1500 "WT" regular cab with basic Chevy "Infotainment 3" 7-inch screen/radio. How many speakers do I have If I want to upgrade? Is the audio amp separate from the radio/display unit]? [I listen to classical and it gets a bit raspy at slightly higher volumes. Don't need a sub etc.] Do I have two or 1 speakers in the doors? etc. Thanks Bill  San Jose
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
