Rear window graphics dimensions .
Hello every one , I’m buying the rear window graphics for my 17 Sierra crew cab . The car is with the dealer for fixing some issue , any one has an idea what is the exact rear window dimensions ?
Online says 63 1/4 into 16.5 , is this correct
Thanks .
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
