Today I raised the passenger side rear seat in my crew cab but when I went to let it back down it clunked and stopped a couple inches from the up position. I reached under to see if there were any latches or anything out of place, but found no reason for not lowering. I checked the position of the seat back while I was lowering the bottom but seemed normal. I repeated the process quite a few times before it finally didn't clunk and lowered. Has anyone experienced this?
Found this thread from 2017, my rear seat is stuck in the upright position! And his solution, I was able to fix it myself. There is a metal locking stop / cam that holds the seat in position. Just look at the opposite side while moving it up/down and you will notice the metal piece that i am talking about by the hinge. You need to use a flat blade screw driver and move the tab to lower the seat. and use a graphite lube or grease to lubricate the metal tab and work the seat up and down to get it working again...worked for me...sorry I can not take a picture of what I'm talking about. I hope this helps you!!
Sorry I haven't tried since. It was about -20f that day it stuck, but it has warmed up.
Edited by jimbo285
miss-spelled
  • 2 years later...
Anybody know what to do when the seat stays down but does not lock up? I can swing it back and forth,
Thanks in advance
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
