4.8---5.3 is ther much
If you don't plan on towing much and can live with a little less HP, the 4.8l is a great choice.
If you are buying new, I would say opt for the 5.3l. You wouldn't regret it and it would help resale value.
I have an '02 4.8 4x4. I've had no problems with it as far as being low on power. There isn't much of a HP difference between the two but the 5.3 has a good bit more torque (50 I think). As for towing, a 4.8 is rated to tow about 1000 lbs less than the 5.3 depending on gearing.
It all depends on what you'll be using it for. I don't tow so I can get away with the 4.8 but I'd prefer to have the 5.3 simply for the torque.
Also, you can always mod it if you need to.
I've got a 4.8L and it's plenty for me. It's also a third vehicle and my daily driver. The only things I plan on towing in the future are my Firehawk and a pair of jet skis and the 4.8L is more than capable of both. That 4.8L will still take anything Dode or Ford has excpet for the new hemi and the 04 5.4L...I really like the motor....I've got to find out what Chevy did to get 285hp out of the 04 4.8 :chevy::jester:
I've sadly to say owned 3 4.8s(see my post, on my wrecks :crazy: ) The engine is a solid engine, and will do anything the 5.3 will do when it comes to the little towing I do. And just to add a note, I ran my truck up against a buddy of mines '01 5.3 and won by half a cars length. :D:rolleyes::smash:
Everyone I know with full size GM's has the 5.3. I have the 4.8. They all get close to 20 mpg (between 17 and 20) I get 16 on a good day. So I would opt for the 5.3 if it were me. If I tow my boat or snowmobile trailer my mileage goes in the toilet. Usually no more than 10 mpg. If I had it all to do over again I would get the 5.3.
In the Yukon the 5.3 gets 1 MPG better on the Highway (according to the GM literature)
Resale value according to the "black Book", you deduct $ 500.00 for having a 4.8
1,000 lb difference in towing ability
I just returned from a 2,100 mile trip of which 1,700 miles were towing a 5,000 lb 22 ft travel trailer. from flat south Florida to the Mountains of North Carolina & Tennessee
I have a '01 Yukon 5.3 & 3.73 axle w/ all the factory tow goodies.
worst millage 11.8 mpg & best 13.6 mpg while towing all at posted legal speeds. I could run 55 mph going up 8% mountain grades with plenty of gas pedal left to go faster if I wanted. The 5.3 is the only engine I wanted when I was looking.
I have the 4.8L in my truck and it has more power than any other vehicle I have had. It would kill the non vortec FI 350 we used to have! I tow about 3500lbs and have no problems even on a 7% grade for 5 miles, I can do 70+ MPH all the way up towing 3500lbs. Mine is in a Reg Cab Short Bed so that may help a little! If you have a choice go with the 5.3 but if not the 4.8 will be fine I am sure!
I have a 4.8L in my 03 Reg Cab Long Bed Sierra. With a bed cover I have gotten 21 mpg on the road and 19 towing our pop up camper (2000 lbs). Around town I average around 16. I have a 3.42 rear end and havn't had any need for more power, even towing thru the Smokies. For me, it was a great choice over the 4.3L that was the base engine. Well worth the $695 option!
I have the 4.8 V-8 in my 2000 Silverado Reg Cab/Long Bed and I love it. It'll chirp the tires everytime if I let it. I get 20mpg on the hwy and about 16 in town. Never towed anything but have hauled some heavy loads in the bed with no problems. It's a great engine!
FUEL ECONOMY
NOTE: Fuel economy regulations do not apply to heavier-duty Silverado 2500, 2500HD and 3500 models and no EPA ratings are published for them. These models and their powertrains are not included in the chart below.
Model Engine Transmission
Estimated MPG City/Hwy1
Silverado 1500 2WD Vortec 4300 V6 4-speed auto. 16/20
Silverado 1500 2WD 5-speed manual 17/23
Silverado 1500 4x4 Vortec 4300 V6 4-speed auto. 16/20
Silverado 1500 4x4 5-speed manual 15/18
Silverado 1500 2WD Vortec 4800 V8 4-speed auto. 16/21
Silverado 1500 2WD 5-speed manual 16/20
Silverado 1500 4x4 Vortec 4800 V8 4-speed auto. 15/18
Silverado 1500 4x4 5-speed manual 15/19
Silverado 1500 2WD Vortec 5300 V8 4-speed auto. 16/21
Silverado 1500 4x4 Vortec 5300 V8 4-speed auto. 15/18
1 2003 EPA numbers shown. Official EPA estimates not yet available. 2004 Silverado estimates based on GM testing.
The facts.
1 Both get the same MPG.
2 There are more performance upgrades for the 5.3 easily available.
3 The 5.3 has more power without question.
I cant tell you what to do but i would get the 5.3 hands down. :D
I towed a 6200# travel trailer with my 4.8 in Texas heat and hill country with out any problems. But, If I were buying again new, I would have gotten the 5.3. It just simply responds to mods better and now the cost difference over the finance term is practicly nothing.
The facts.
There is not a single mod availiable for the 5.3 that is not available for the 4.8. :)
I've had the pleasure of having both a 2002 4.8L and a 1999 5.3L - basically, the 99 5.3 makes the same 270 hp as the 02 4.8 but has a little more torque - not sure how much. Which one is better? Easy, the 5.3L!!!! (especially with the Predator programmer!!!!) :)
I would think either motor would work for you. I really like all the GM gasser engines. All I think are bullet proof. I mean look the 4.3, 4.8, 5.3, 6.0 and the 8.1 all bada$$ powerplants.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
