08 GMC 1500 2WD Transmission Fluid Change info?
I have a 2WD Sierra 1500, 5.3 non flex fuel with about 95K on it and I think it's time to change the transmission fluid and filter.
What is the volume of oil that the transmission requires?
Does synthetic fluid make any difference/benefit???
Thanks
If you are dropping the pan, you will only need 5-6 qt. If you are using the cooler disconnect method, you should have 3 gallons on hand.
Regular and synthetic are interchangeable. Most rebuilders are using synthetic due to ability to withstand harsher conditions , but if you are nice to your tranny, regular is fine with proper maintenance.
    ballencd
    ballencd
  • Who's Online   3 Members, 0 Anonymous, 455 Guests (See full list)
