Towing 20' enclosed Haulmark car trailer w/98 1500
I just bought a 20' enclosed Haulmark car trailer. I will be towing my '93 vette with it. The total weight will be 6,700 lbs. I have equalizer bars on the way. My truck is a '98 1500 4x4, ext. cab, 6.5' bed w/a cap and 5.7 litre. I would like opinions on how you guys think it's gonna do. I would especially like to hear from you guys who have towed as much or more w/ a truck similar to mine. BTW, I'm only towing this trailer with this truck 'till October, I"m getting a 2500HD in the spring.
We towed a 16' Haulmark tandem loaded that weight about 7000lbs. with a 4.8 Sierra. The trailer would push the truck around on the interstate but we only pulled it about 10 miles at a time. The 350 should do just fine. We got another trailer and ended up buying the Dmax. It doesnt even break a sweat pulling the Haulmark.
Add a little more here. The main problem towing here was that the Haulmark we have has the 6" extra height option and it pushes a lot of air. I dont think the weight was as much as a problem but more the air resistance. With a cap that should help you.
You won't have any problems especially if you have 3:73 gears in the rear.I used to pull a 29' travel trailer that weighed about the same with my 97 K1500 Z71 and that truck was a MAN :smash:
OK here's the update. The truck seems to be almost maxed out. It averages 9.3 MPG with this trailer. With the equalizer bars the suspension doesn't sag really much at all. The only problem is when I don't get a running start coming up to a hill the transmission makes a LOUD ping, I mean LOUD. The sound of metal hitting metal kinda sound. I checked the fluid and the u-joints and they're fine. I think my trans might be taking a little bit of a beating.
My 98 Yukon tows my ZR-1s with ease on my open aluminum trailer.
I borrowed an enclosed 20 ft once and anything over 60 mph felt scary.
I have seen many towed with a 1/2 ton truck, just be careful.
I used a friend's '97 Suburban (5.7) to pull my 24" enclosed car hauler one day last year. The truck did it, but it wasn't happy about it. It was working to pull at 65-70 MPH and I was waiting for a little finger to come up on the dash when I tried to maintain speed while climbing hills. I'm used to pulling with something that has close to 200 more horsepower so it was a very noticeable difference to me.
Are you sure the pinging is coming from the tranny and not the engine (possible detonation)?
Tom
The noise I hear is a clunk coming from the trans when it shifts gears while going up a hill w/the trailer. Usually it does it quitely but a few times it was very loud and could be heard over the radio.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
