Jump starter
Looking for a jump starter to keep in my truck.  Any suggestions for a good one?  I know instant amps are important for the large size battery I have.  I have a 2008 GMC 2500HD 6.6 LMM.  I've been looking at the Dewalt jump starter.  (Not having any problems. Just would like to have one just in case)
I have a NOCO GB150. Supposed to be able to jump up to a 10.0L gas or diesel.
Best price I could find on it was from local GM dealership and has a GM part number since it is listed on the accessories website.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
