New shocks for lifted truck
Hey y'all, Would like to upgrade the shocks on my 15. I currently have Rough Country's 3.5" lift kit on, with their original shocks. The ride is MUCH worse than I expected it to be, and after 25k miles I decided I'd like to throw some new shocks on and call it a day. Rough Country released their new "Vertex" shock which I thought about trying but am weary about quality, as I haven't been all that impressed with their other products, and at ~$1400 for the kit I'm not willing to take a chance. As of right now I've narrowed it to Bilstein 5100/5160's or a set of Fox. My main issue, is that neither has a shock rated for a 3.5" lift. Can I run a shock that's for a 4-6" lift? and with my rear having a 1.25" block, can I run a 0-1" shock? open to suggestions and other brands as well!
i cant speak to your question regarding running the appropriate sized shock, however, I will say that I am at 8" of lift and switching to Bilstein 5100's this weekend. I'll let you know how they ride
Could the reason your truck rides like dump now be due to poor front end geometry more so than your shocks? Is that lift kit a true lift or a key kit?
Hey Ryan
So update on the Bilstein 5100's
All four sides are super easy to install. As I'm lifted 8", it made it even easier to reach everything. The ride definitely improved and even more so after taking about 10-15psi out of each tire. Now that I'm at 50/55psi, it is much more pleasant to drive and feels more planted over bumps in the road.
it's a true lift, and front end geometry is still very good. came with spacers for the diff, new UCA, etc to maintain stock geometry.
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,318 Guests (See full list)
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
